Hi Patrick
In your templates scripts.php (../templates/j51_boutique/php/scripts.php) locate the following block of code...
(function($) {"use strict";
$(document).ready(function() {
$('#header_slide').vegas({
delay: 5000,
timer: false,
slides: [
<?php
if(is_array($header_json['header_slide_image'])) {
foreach($header_json['header_slide_image'] as $value) {
{ src: '<?php echo $this->baseurl ?>/<?php echo $value; ?>'},
<?php } } ?>
})(jQuery);
</script>
In which you can edit the delay to your own taste...
delay: 7000,
