1. Chris
  3. Sunday, 01 March 2015
Hi Ciarán,
I purchased the Boss template and uploaded it and set it as the default template but its not showing up on the frontpage? I switched templates to another template and this one did show up. Any ideas as to why? I just migrated to joomla version 3. I do have someone who is going to take a look at it but I though to ask you too.
Chris
Hi Chris
Hi Ciaran, it was a migration issue (errors) not a template issue.
I also used the custom CSS to move the menu up under the logo which I found in a post on the forum.
What I would like to do is move the content up under the menu more as there is a big gap between the menus and the page content. Is there a custom CSS? I did email you login detials for the other issue, if you want access to the site as its offline at present.
Also can the footer menus be turned off?
Chris
Hi Chris
I am unable to locate your access details. Could I ask you to forward them once again to [email protected]. Please ensure to include a link to this post in your email for our reference.
Thank you Chris
To tighten up your spacing in your header try adding the following to the Custom CSS field of your templates parameters...
#hornav {
padding-bottom: 0;
#slideshow.block_holder {
margin-top: -60px;
padding-bottom: 0;
