1. profialarms
  3. Saturday, 30 January 2016
Hello, please help me with DPCalendar with Boss template. An event can not be clicked, the page is always restarts and freezes.
http://www.3mont.cz/stavajici-zakaznik#year=2016&;month=1&day=28&view=month
Thanks Filip
Hi Filip
This appears to be a local issue. We have tested your Calendar in both Firefox and Chrome and it appears to be working without any issue. Are you having the same problem if you enable on of the default Joomla templates (Protostar)?
Hey, if I switch to Prototar template and calendar functions properly. why do not angry at the template Boss? Thank you Filip
You appear to have a large number of plugins installed (Extensions -> Plugin Manager). May I suggest uninstalling any plugins which you are not using as they may be causing a conflict with your calendar form. Also worth removing any modules which are not been used. The following articles details how you can remove the demo module positions... http://www.joomla51.com/tutorials/item/cleaning-modules-from-demo-installer
Finally try temporarily disabling modules on your form page to ensure there is no conflict there. Failing that please get back to me and I will take another look.
