1. ziggy
  4. Wednesday, 24 October 2012
Dear Designer
I have bought your theme "Bourdeux" directly on you web site J51 but I have found some problems. The problem is that I cannot upload pictures on normal article or Module (Imagen 2). And I have also the problem that the articles showed as a Blog form they show up with a not correct form.
My version of Joomla is 3.0
thanks in advance
Hi Terceño
May I suggest sending temporary adminstration access to your Joomla installation to [email protected] and we will examine this issue further.
We have send it to you. so I holpfully that you can find that problem.
thanks in advance, by the way, we want to buy new templates for other web sites but until we don't know what is going on, we will wait... we new add images and so on
thanks
The columns issue has been amended by adding the following to the Custom CSS field of your templates parameters.
[code type=css].blog .column-1, .blog .column-2, .blog .column-3, .blog .column-4 {
padding: 0 20px 0 0;
width: auto !important;
.items-row .btn.dropdown-toggle {
margin-top: 27px;
}[/code]
This was due to an issue with our template with which I wish to thank you for bringing to our attention.
The images issue appears to be related to your server settings, in particular with 'Magic Quotes' been turned on. May I suggest the following Joomla forum post which relates to a similar issue as in your own Joomla installation.
