1. Drew
  4. Wednesday, 08 April 2020
Good day!
It appears as though the bicon Icons can no longer be found via the link in the Naomi Template, nor an internet search for a list set.
I was looking at adding an additional column to an existing module, however I can not find list set to choose from :(
Link provided in template; Bicon: http://bicon.lab.themebucket.net/
Are you still using them? Has it gone by the wayside, or purchased by someone else?
Thank you - Drew
Hi Drew
I am sorry to say that the Bicon font has been discontinued by the original developer so we had no choice but to remove it from the J51 Icons module.
Please find attached the latest update to this module.
Thanks Ciaran,
If I install this, will I need to be prepared to change some of the previous icons currently being used?
- Drew
Hi Drew
If you are using the Bicon icons, then unfortunately yes. The Bicon icons will no longer be displayed.
