1. bludove
  4. Thursday, 02 June 2016
Hi:
On your template "Beaumont" http://demo.joomla51.com/0131/ I have a question:
For the main opening picture, is there a way we can eliminate the image fading at the bottom before you scroll and while you scroll? So it is just a solid picture?
Thanks!
#header_bg_grad {
display: none;
