1. SloekTemp
  3. Tuesday, 07 March 2017
L.S.
I installed the Serenity template but I can't get the background image on my site...
The background image "images/header-bg1.jpg"
In the Serenity test install I find a "vegas-wrapper" .... how can I install this on my website ... I can't find anything in the backend.
Thanks in advance
Peter-Paul Sloekers
<div class="vegas-slide vegas-transition-fade vegas-transition-fade-in" style="transition: all 1000ms;"><div class="vegas-slide-inner" style="background-image: url("/serenity/images/header-bg1.jpg";); background-color: rgb(31, 23, 28); background-position: center center; background-size: cover;"></div></div>
Hi Ciarán,
I'am afraid not ... It's a test installation on a local XAMP server ...
Image for the vegas wrapper are set within your templates parameters. From your Joomla administration navigate to Extensions -> Templates -> [YourTemplateStyle] -> Styling and add your image(s) in the corresponding field (Header Images).
Thanks for your reply and sorry for the late response ...
I did use the parameters to install the background image ... It only took a while to find out that an installed extension was blocking the wrapper ....
Uninstalled the extension and all works fine !
Peter-Paul
