The Autson Slideshow on my website (http://www.aleyce.com) seems to be frozen on the first image and has stopped showing the 4 images that i have assigned to it.
A possible solution is to turn on jQuery if not already on in your modules parameters. From your Joomla adminsitration navigate to Extensions -> Module Manager -> AutsonSlideShow -> jQuery.
jQeury already seems to be turned on..
the version that it is using is 1.5.2(local copy).
is it possible that this is the wrong version?
Is it possible that a plugin that i have uploaded to the site is interfering with the slideshow?
Great.. I'm pretty sure I disabled it before loggin out of your site. If not you'll will find it in your Plugin Manager (Extensions -> Plugin Manager).
