1. OhLordyy
  3. Tuesday, 06 March 2012
Having an issue with this template where as when I have it as my default template all the Java based elements do not work and the fields seem to overlap for the text areas. This isn't an issue when another template is set. Any suggestions or ideas please.
If you need to visually see the issue, I will put the site back on-line. Just let me know since it is a site under development. Thank you
Could you put the site online and a URL to an example of the issue and we will examine it further.
Thanks for the swift reply .. the url to the an example of the issues is as follows .. after you have viewed it let me know and I will make the other template active so you can see how it looks when the java is pulling correctly.
The Golf Portfolio
I think I see the problem. Both the template and your plugin are both using the #top ID causing a clash in CSS. To change the ID used by the template firstly open the templates index.php (../templates/j51_atlas/index.php) and change the following (line 102)..
<div id="top">
change to...
<div id="j51top">
Next open the templates template.css (../templates/j51_atlas/css/template.css) and change the following (line 34)..
#top {border:0; paddi.......}
and change to...
#j51top {border:0; paddi.......}
Hopefully that should solve the problem.
hmm are you sure about line 102 in the index.php file . it reads
<div id="hornav_center">
I have changed to another template so you can see the functions and layout that works well but isn't as sharp or nice as your template looks ..
Should be in that area... a few lines before <div id="hornav_center">
If you wish you can email temp access to [email protected] and we can make the amendments for you.
will do that . .but if you look now at the site .. you will see at the bottom of the page on the link I sent you how the java is pulled correctly which it isn't with your template .. also the top portion where the photo is works on this one . lol ok I need another photo to really let it slide
also after the change . I lose the center nav on the home page . lol
yep .. fixed that thank you .. line 98 for the index.php file ..
how about the java aspect not working ... do you need access for that ?
if so .. just email a normal username and password ur comfy with .. and I will give you access to the server
Any user/pass will be fine... we're not particular (",).. email to [email protected]
ok .. lol can make wild passwords .. is there a particular heading or subject title you like me to address the email as ..
also noticed on the right sidebar the module is cut off doesn't do the whole field of the module listed there
Just mention the forum here and I'll be sure to pick it up. I'll also look at your side module issue.
Thank you for correcting the issue in a highly professional and timely matter. Your customer service and communication was excellent as you kept me completely informed of your progress daily.
I will purchase not only another templates from you, but also recommend your services to others.
Again thank you and your team very much.
