1. KChev
  4. Friday, 08 January 2016
I'm working with Artisan and find that the (regular, not layer) slideshows images are cut off a bit at the top. The template width is set at 960, the slides are 960x400 for one set and 960x600 for another and they are in the showcase position. Is there a depth limit for showcase slides in this template?
Update: This seems to occur only when the window is wide enough to show the left side, not when the page is fitting to a device screen.
Would you have a URL to an example of the issue so I can better understand your query?
That part of the site is not public yet so I'll send you a direct url by email.
The custom css you emailed me had no effect. In the end I simply adjusted the placement of the text in the image to allow for the cropping. However, I'm having a similar cropping problem with the grid gallery that came with Artisan. I have 3 square images, 400x400, set for 260 width in the settings. Unlike the slideshow, the images in the gallery are cut off at the bottom in every view (desktop, tablet, phone). These are images that must be square so I can't do a work-around. The site is public now except for this section I'm working on, so if you need a URL I will email it to you.
I noticed that someone else was experiencing this problem with the Layer slideshow.
Thanks in advance.
Could I ask you to forward a URL to an example of the issue. If sent by email ([email protected]) please include a URL to this post for our reference.
To revolve you can add the following to the Custom CSS field of your templates parameters...
figure.snip1156 {
max-height: none !important;
Perfect for the grid gallery. Pity it doesn't solve the slideshow issue but this was more important. Thank you!
