Hi!
Artisan menu is originally set to position-7.
If I add another module (latest) also to position-7, it won't show.
I have also tried to set the modules (meny and latest) as position hornav. In this case, both the modules shows but not under each other, just next to each other.
Is it not possible to have two modules in this position?
If not, what is the alternative? A top module for the menu would be fine, but - for example if set to module top 1A, it won't stay in scroll.
This is a local installation so I can't show you the problem, I hope you understand anyways.
