1. Rocca
  3. Thursday, 19 November 2015
Hi there,
maybe it's an easy question but i'm not able to add an image in the slide show. The module is correctly installed but when i try to add an image to the list i get an empy pop-up with just a + and - icon but no way to choose the image ... no button no label nothing ... am I doing something wrong?
Screenshot as attachment
Hi Rocca
E-Mail with access sent!
Tnx Ciaran
Thank you Rocca
This field of the templates parameters uses the 'repeatable' Joomla field type (https://docs.joomla.org/Repeatable_form_field_type). This field type has been noted as having some issues on earlier versions of Joomla 3.x (https://github.com/joomla/joomla-cms/issues/5868). May I suggest updating your Joomla installation to the latest version of Joomla which should hopefully resolve this issue for you.
Hi Ciaràn, i've update Joomla to the last version and re-installed the module and now it works fine ...
Tnx, regards
Great :)
Thank you for the update!
