1. williams
  3. Friday, 20 June 2014
Using Renovate. http://71.19.236.215/
I've tried everything and I still can't seem to get articles or new modules to show on my site. And can't seem to find a "system output" or anything in the template manager.
Please advise.
Stephanie H.
Hi Stephanie
There appears to be a compression running on your CSS files which is causing some issues with your template styling. Regardless adding the following to the Custom CSS field of your templates parameters should resolve this particular issue...
#container_main {
display: inline-block;
This did the trick. Thank you!
Not sure what kind of styling issues you see though. Is it supposed to be looking different somehow? I haven't turned on any compression, but did notice that the css was compressed when I opened template.css.
Have double-checked that I don't have any compression plugins installed and haven't activated gzip or anything like that anywhere.
Any clues?
Steph
Hi Steph
You could check with your host to ensure that there is no server side compression running. However if you notice no other issues you could probably leave as is but would be worth keeping in mind if any issues arise in the future.
