1. jasonbrinn
  3. Monday, 25 March 2013
Good day,
I would like to add the "Module ContentTop-A" module to the list the turns off when under 480. If possible, how can I add this module so that it disappears once the site is scaled to 480 or less?
Jason
Hi Jason
Try adding the following to the Custom CSS field of your templates parameters...
[code type=css]@media only screen and (max-width: 440px) {
.wrapper_contenttop {display:none;}
}[/code]
Thanks but it did not work. It gave me some ideas though and I will try them and report back if anything does work.
still no louck :(
Any other ideas how to make this module position disappear under 480?
thanks.
You could try using the following instead.. this would cover both landsape and portrait...
[code type=css]@media only screen and ( max-width: 767px ) {
}[/code]
Also worth trying to add the CSS to the end of your templates nexus.css (../templates/[YourTemplate]/css/nexus.css)
Thanks again, however, nothing seems to work.
Hi Jason
Would you have a URL to an example?
Hi Jason
Strangely your Custom CSS does not appear to be loading with your template. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I sent you a login response to your email, did you get it?
Hi Jason
We don't appear to have received your administration details. Please ensure you have posted a link to this post with the email including your login details for our own reference.
The suggested CSS needs to be added to the template style that you are using for the page you wish to disable the module. You seem to have quite a few template styles created so I wasn't to sure which one was applied to the homepage.
Sorry. Yes, I used a lot of template styles in order to change the logo mostly.
Here is the default one that I use for the homepage:
J51_Arkadia - Default Site J51_arkadia 221
Thank you!
Try checking that none of the other template styles are assigned to your homepage as this style does not appear to be the one represented on your homepage. For example this style has no background image selected but there is a background image on your homepage.
I replaced the default background image that is why one does not appear to be assigned.
I also went ahead and added the custom CSS code to every template and made sure the default was the only one assigned to home and the issue still persists.
Thank you.
Hi Jason
I have added the CSS to your templates nexus.css and everything now appears to be working fine.
Absolutely awesome!
I would never have expected such attention and help from a company that charges so little for such superior products. I am/have been a member of just about every Joomla template club there is:
A LifeTime member at Gavick, current member at Yootheme, Joomlart, Rockettheme
Past member of Template Plazza, YouJoomla, JoomlaXTC, Shape5, etc.
You guys are the BEST and ridiculously low prices.
THANK YOU!
Thank you Jason for your very kind words.
Any further queries please feel free to contact us and we will be happy to help out where we can.
