1. kaiserf
  4. Sunday, 15 February 2015
Hello cirian,
My customer wants to install in the template "alexis" the slidshow "JSN Image Show" by jsn.
My question is: Can I adjust a slideshow with 100% (attached you'll find the picture).
Additionally the drop-down menu is always shifted behind the Slidshow.
May you can help me?
LG Franz
You will need to use some custom CSS to achieve this however a solution would depend on how the extension creates the slideshow. Would you have a URL to an example of this slideshow within your template?
Hello ciaran,
enclosed the link to the website.
Link to the test side
Best regards Franz
Thank you Franz
Try adding the following to the Custom CSS field of your templates parameters...
.container_skitter, #container_slideshow, .container_skitter, .container_skitter img {
width: 100% !important;
Hello ciaran,
Thanks for your help, unfortunately, the code does not work.
I noticed that in the J51 Slidshow a small error is included.
If the setting is set to "Show Prev / Next" Yes, 100% of the Slidshow be displayed. But the setting is No, then the Slidshow is reduced to 1080px.
When I view the J51Slidshow and JSN-Slidshow the same time, the JSN-Slidshow to fit the 100% (full width of the screen).
I also tried some in the CSS (eg: .container_skitter, #container_slideshow .wrapper960, .slideshowcontainer, .container_skitter, .container_skitter img {max-width: 100%! Important;}) switch. Unfortunately I can not get the desired result.
LG Franz
Hi Franz
Have you since found a solution to this as your slideshow is now spanning the full width of the browser (Firefox)?
Hello ciaran,
no not yet, but I'm working on it. I need to find the connection between the two commands #container_slideshow .wrapper960 and .slideshowcontainer. Here the philosopher's stone should be buried. I hope so.
LG Franz
Hi Franz
By default this are of your template is 'boxed'. You can convert this to 100% width with the following custom CSS...
Hope this helps!
same problem for me:
if prev/next is disabled in the slideshow module than fullsize of the images is not available.
I tested both of your coding examples, none is working.
Currently I enable prev/next again but this shouldn't be the solution I think ;)
Any other ideas?
Thx in advance
Oliver
Hi Oliver
Thanks for helping me in this case Ciaràn.
The email is on its way.
Oliver
Thank you Oliver
I have installed the latest download of the J51 Slideshow module and it appears to be now working correctly.
