1. Edgar68
  4. Thursday, 17 September 2015
Hi Carián,
Is it possible not to slide the picture to the right when, you hover the mouse over picture.
But to display the picture centered, And to keep it like that.
Image caption TITLE the same, as now
and the image captions text comes up also the same as now.
The only difference is not to let slide the picture to the right.
Gr. Edgar
To disable the transform of the image on hover try adding the following to the Custom CSS field of your templates parameters...
figure.effect-lily img {
transform: none !important;
Ciará
Hi Carián,
To disable the slide, it works !!! Great !!
Thanks for that.
But now the pictures are not shown centered, but a little to the right.
I think it is the distance of sliding the picture before.
Is it possible to view the photos immediately centered?
Gr. Edgar
Hi Edgar
To center try replacing the above CSS with the following....
width: 100% !important;
Ciarán,
Thank you very much for the great support.
Awesome !!!!
Gr Edgar
Hi Ciarán,
There is a different problem now.
The display of the photos in Grid Gallery on Apple Ipad is not good.
On all other devices, it's okay.
The problem is as follows:
The photo display is not good.
This is the play on other devices:
Can you help me to solve this problem?
Gr. Edgar
THank you
May I suggest the following Custom CSS which will reduce the size of your GridGallery text on smaller screen devices...
@media only screen and (max-width: 959px) {
.j51gridgallery figure h3 {font-size: 18px;
Hi Carian,
i added it, but the pics are still shown the same.
the text is ok and visible, only the pics are not centered.
Gr. Edgar
Hi Edgar
Could I ask you to repost a URL to an example of the issue. It appears to have been removed from the above post.
Hi Carian
Here the link..
Gr. Edgar
To amend try changing the first suggested Custom CSS to the following...
-webkit-transform:: none !important;
Hi Carian,
I have added it.
now there is a problem with safari browser.
on the other browsers it is ok..
the link to the page:
I hope you can help me to solve this problem
Gr. Edgar
Try covering all browsers with the following...
-o-transform: none !important;
-ms-transform: none !important;
-webkit-transform: none !important;
I added it but it is still not working... :(
The picture slide to the left is still working on Safari.
What can i do now?
Gr. Edgar
Is there someone, who can help solving me this problem?
Gr. Edgar
Hi Carian,
done.
Gr. Edgar
