1. smithjd44
  4. Wednesday, 15 August 2018
I just built the website located at the link: http://regenerativemedicinedfw.com using the Sophia template.
I used to be able to increase the font size of the top menu bar fairly easily but since this template has the sticky menu, could you let me know where in the CSS code I can increase the font size?
Or is there some custom CSS code that you can give me and I can add to increase the font size of the main menu and of the drop down menus?
I appreciate you assistance!
James
BTW: I love the Sophia template and have used it a couple of times already!!
  1. http://regenerativemedicinedfw.com
Hi James
Edit to taste
.hornav > ul > li > a {
    font-size: 16px;
