1. roryHaze
  3. Wednesday, 10 September 2014
Hi there I am using the joomla51 Choice template, I am trying to add a menu selection beside the austin slideshow, I have the slide show in the 'showcase' position and i want to add the menu directly to the right of that. Is it possible to share the one position or do i have to stick to the set position of the template?
Would you have a URL to an example of your slideshow and menu placed in the 'showcase' module position and we will see is it possible with some custom CSS to align them side by side?
the URL is thomaswalsh.ie, I am looking to place the menu to the right of the slideshow on the home page. Would it also be possible to make the slogan text size bigger?
Thanks for the quick reply as well!
Rory
Hi Rory
We will need you to create a menu module in the 'showcase' module position along with your slideshow for us to put together the needed CSS.
