1. chrishoefliger
  4. Friday, 02 September 2022
Hi Ciarán,
I recently bought Skylar for Joomla 4 as an update, because I wanted to upgrade one of my sites to J4 and I thought it best to use the same template.
Anyway, the update ran through and I was able to install Skylar. The site I'm working on is now alsmost complete, but it's still on my localhost. Maily because I still see some strange things, namely 404 errors when I look at the network tab in dev tools.
For one, the template insists to look for a favicon file in the root, which is not where favicons used to live. Strange. Now that's easy to fix, one places a favicon file there and the 404 is gone (but I still think this is not the way one should deal with this).
What bothers me more is that somehow the template also looks for
/media/templates/media/vendor/joomla-custom-elements/css/joomla-alert.css
Needless to say, there is no such folder, and if there was, it should rather be under /templates (I see there already is a similar thread on this elsewhere in this forum, but it's not resolved).
Also somehow there is a missing file
/images/base-bg.jpg
where I do not have the foggiest, what this means. There was no such file in /images in the J3 version of the site and to my knowledge there never has been. The initiator of this 404 is said to be jarallax.min.js.
Any suggestions?
Cheers, Chris
Hi Chris
This is an ongoing issue that to date we have been unable to replicate and one that is a bit strange. The joomla-alert.css although provided by the template, this file is actually loaded by Joomla core. May I ask have you enabled any child templates? Is this file available at ../media/vendor/joomla-custom-elements/css/joomla-alert.css?
Hi Ciarán,
yes, the file lives at the said location, but not at /media/templates/media/vendor.... and no, there is no child template involved.
Hi Chris
I have just created an update to the Skylar template which should hopefully resolve this issue. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
Hi Ciarán,
thank you so much. I'll give it a spin and will get back to you!
Cheers, Chris
Hi Ciarán, we're talking about this one:
Version 1.1.6 - 8th September 2022
+ Add js/jarallax.min.js.map
# Fix not found error on joomla-alert CSS
I've installed the version and I'm afraid I have some bad news: It does not change anything, the 404 is still there
I've put the site online and I'm sending you the details of an temporary admin account.
BTW jtaldef is a plugin that downloads google fonts and makes them available locally. Switching it off and clearing caches does not change anything.
Thanks, Chris
Thank you Chris
Could I ask you to allow us access to your extensions manager so we can edit your template?
Thank you Chris
This issue is proving to be particularly stubborn. All calls for the joomla-alert.css have been removed from the template and we instead added this CSS to the main template CSS however Joomla continues to attempt to make a call to ../media/templates/media/vendor/joomla-custom-elements/css/joomla-alert.css
We will continue to search for a solution and will likely need to chat to Dimitris who developed the joomla-alerts custom elements for Joomla and try and find a solution. Our investigation so far makes us think that there is a possible issue in core for 3rd party templates.
In the meantime may I suggest copying the contents of your ../templates/j51_skylar/css/vendor/joomla-custom-elements/ folder to ../media/templates/media/vendor/joomla-custom-elements/ which should hopefully resolve this issue for you.
Hi Ciarán,
thank you. Will do as suggested and wait for improvements.
Have a nice week end, Chris
