- POE
- Pre-Sales Question
- Friday, 18 August 2023
May I suggest the following article on this topic.. https://www.joomla51.com/tutorials/demo-installer/setting-up-the-demo-installer
Merci Ciaran, I had read this tutorial what gave me the impression, that it is not planned to install your Templates after Joomla4.0.
But I tried and did upload the whole 46 MB zip file.But now I received two messages:
JInstaller.: Install: XML-Installation-file could not be found.
Manifest-data set could not be found.
Where do I find these files? Is it necessary to unzip them before uploading? Or...?
Ciao Wolfgang
Ciao Wolfgang
Meanwhile I went the long way, unzipped your Layla Demoinstaller and uploaded all files to the MySQl database, where Joomla 4 and the Layla template were already installed. Now I see on frontend "Layla Home" but not the Demo version with the sample data with the design I would like to use. How to change ?
It looks like you are trying to install Joomla into a folder called "J51_Layla_DemoInstaller". If this is the case then open this folder in your browser (eg. http://www.yoursite.com/J51_Layla_DemoInstaller) to start your Joomla installation.
Merci Ciaran, problem is solved!
Now appear in two positions with icons (top-3 and bottom-1a) and also in the main ("welcome to Layla":
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in....
and Unable to find a user with the ID: 842 . That´s not me.
How can I get rid of these?!
Ciao, Wolfgang
Ciao, Wolfgang
I did send you all administrator accesses (ftp, MySQL, Site) 5 days ago and finished my adoption of the Layla-layout.
I neither need the progress bar nor the icons, but a clear homepage. Is it possible to clear the problem in top3 or should I better switch off this row?
Or is it a deeper problem and I better use another template?
What´s the best?
Ciao Wolfgang
What´s the best?
Ciao Wolfgang
Thank you Ciaran,
it works well, looks nice and there are no further problems. Now I nearly finished all my adoptions of the template.
So I need to clean and prepare my website for SEO. My question is, do you (J51) provide such a service like a technical SEO check with adoptions and how much would it be for a website like mine?
Wolfgang
Wolfgang
- # 9
Hi Wolfgang
Thank you for considering us, however, I am sorry to say that this is a service we do not currently provide.
- # 10
