1. dautrich
  4. Friday, 04 August 2023
I have a small issue with Skylar's CSS: I tried to adjust the padding-bottom for class ".contentbottom .module_surround". But this is hard-coded with an "!important" in nexus.css:
Would it have negative effects to remove the !important there?
Rolf
will you remove the !important directive from nexus.css (lines 2079 and 2082, see screenshot above) in the next version of Skylar_J4? To do so would help me a lot, because then I can change the values in custom.css without fiddling around with the nexus.css versions on each template update.
Thx and regards
Rolf
Hi Rolf
We have created a new update for our Skylar template including this amendment.
Hi Rolf
I can't think of any negative affect if removed.
