1. silvias1963
  3. Saturday, 17 February 2018
Hallo,
i use the template "Ashley".
When using the smartphone, the login button does not work and sometimes no keyboard will appear.
Can someone help me?
Regards, Silvia
  1. http://hoffnungskirche-herten.de
Many Thanks. The problem is actually solved.
Silvia:D
Thank you Silvia
To amend try adding the following to Custom CSS field of your template settings...
.backgrounds {
display: none;
Hallo, Ciaran!
The Login-Buttons... :D
the issues is here:
https://hoffnungskirche-herten.de/hoffnungskirche/planungstabellen
https://hoffnungskirche-herten.de/hoffnungskirche/interner-bereich
These links can be reached via the social media buttons.
Silvia
I think you use this process on your PC. OK
Hi Silvia
Is the issue with the login module at the following URL?... https://hoffnungskirche-herten.de/hoffnungskirche/intern-login
Have you considered creating a menu item directly to the Users -> Login component?
