1. Oliver
  4. Tuesday, 19 September 2023
I have a kindly strange behavior with the layerslideshow on j51_emani.
We use the slideshow with overlap function. It works fine on the first 4 pages on the website but on the 5 page it does not show the caption.
The 5th page is a form with RSFormsPro. I can add it as direct menu item or as module. I tried both but no difference.
If I use it as module and disable the module, the caption appears, if its enabled the caption in the slideshow does not appear.
If I check the div's of the form none seems to have influence on the showcase module.
Can you pls have a look on this and maybe you have an idea what we can do to show the caption on htis page too?
Its the menu item "Bewerbung" that does not work correctly. All others do fine.
The whole site is on developement on my dev server so its not live yet.
Thanks in advance for any idea
Oliver
  1. https://dev.lorch-webdesign.de/_schweiger/bewerbung
I had to add " !important" but than it worked fine :)
Thank you very much... you saved my day !
Oliver
Hi Oliver
.layerslideshow141 .info {
opacity: 1;
