1. mabutaha
  4. Thursday, 15 September 2022
Dear Ciaran,
I have created a second menu in certain pages (a bit similar to hornav) at Top-3a position.
An example of these pages https://www.afmssc.com/index.php/about/csr (you may access the site with your previously set access)
Is it possible to make it stacking under the hornav menu when scrolling down? I tried multiple codes with no luck!
If that is not possible, another option is to move it to showcase position, in this case, would stacking be possible?
Thanks,
Mai
Hi Mai
#container_top2_modules {
position: sticky;
top: 125px;
Thank you Ciaran, that worked but not perfectly.
The second menu is now sticky but with the following problems:
1- Menu is no longer clickable once it sticks.
2- Once it reaches the bottom modules during scroll down, it hides backward.
Here is an example page:
https://www.afmssc.com/index.php/about/who-we-are
To amend try replacing the suggested CSS with the following...
position: sticky;
top: 125px;
z-index: 100 !important;
Genius!!! Perfectly as needed!
