1. Oliver
  4. Monday, 16 January 2023
I might have a little issue on j4 version of the template J51_Harmony.
In the template options I choose sticky header = yes but this does not work.
As I see in J3 version there is a change in the class "header_row" while scrolling.
In start positon of the page the code looks like this:
<div class="header_row" style="">
If I scroll down it changes to
<div class="header_row" style="position: fixed; top: 0px;">
Is there a workaround for fixing this?
Or can you pls fix it for a new version of the template?
Any help would be really appreciated :)
Thanks in advance Ciaran.
Oliver
Hi Oliver
My apologies on the delay with this issue... it took a bit of figuring out to find a solution!
If the issue persists after updating, may I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
thank you very much. It works fine :D
We really appreciate this because we have more than one customer with this template. :)
Oliver
Hi.... I have the same problem, but its not working. I did download and installed the new version of the template.
Regards,
Hedi
Hi Hedi
Good morning Ciaran - now it works fine. After installing the new version it did not work, but after rebooting my computer it did.
Thanks anyway for you help.
Regards,
Hedi
